my first cast
See more from JRay8
JRay8
Arnold, MD
Gatsby click T/N with big leaf maple cast in blue acrylic. I learned alot from this and thanks to advise from several of you guys i have started new casts that are much better. on the back side you can see a major finishing mistake. i believe i sanded the CA away on one end and did not notice it because the wood was wet from the wet sanding. by the time it dried i had the pen assembled :eek:. thanks for looking...
BSea
Little Rock, Arkansas
Although I'm not positive about the click pen, the regular Gatsbys are pretty easy to disassemble. Then it wouldn't be much trouble to refinish. If you have a Harbor Freight, they have a set of punches that work well for pen disassembly.
