My first bespoke pen - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Show Off Your Pens!
  Forgot Password
Show Off Your Pens! Let's see your best work!
Welcome to penturners.org!
Reply
Old 02-21-2019, 12:47 PM   #1 (permalink)
Photos: 3
Default My first bespoke pen
I donít have the right tap and die for the cap threads yet but overall I am very happy with the outcome of my first bespoke pen. I used a #6 Jowo nib and wanted to keep the overall diameter to a maximum of 14 mm since that appears to be a comfortable size for (my) daily use. Also included, an image of the mandrels I made to turn this pen.
Best Regards,
Edwin
DutchPlatypus is offline   Reply With Quote Top
Old 02-21-2019, 12:52 PM   #2 (permalink)
jttheclockman's Avatar
Photos: 104
Default
Looking good from here. Good to experiment and when things work out it feels great. keep up the good work and keep posting your work.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 02-21-2019, 01:51 PM   #3 (permalink)
magpens's Avatar
Photos: 76
Default
Congratulations on your first bespoke pen !!! . Very nicely done !!!
One of your mandrels seems to be marked "1/2 - 28".
Is that the thread size of the cap to body thread ?
BTW ... you could have entered this pen in the Kitless Contest that closed only about 15 hours ago !
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Advertisement
Old 02-21-2019, 02:28 PM   #4 (permalink)
Pen Joe's Avatar
Photos: 0
Default
nice like the rounded ends, real nice.
Pen Joe is offline   Reply With Quote Top
Old 02-21-2019, 05:07 PM   #5 (permalink)
Jim15's Avatar
Photos: 66
Default
Great looking pen.
__________________
jim,
Hamilton, Ohio
Jim15 is offline   Reply With Quote Top
Old 02-21-2019, 06:10 PM   #6 (permalink)
OZturner's Avatar
Photos: 103
Default
Attractive Pen, Edwin.
Excellent Profile, and Proportions.
Nicely Turned and Finished.
Congratulations,
Brian.
__________________
Turn that special piece of Timber you have been keeping.
Enjoy it for its true beauty.
Why leave it for others to enjoy without you?
OZturner is offline   Reply With Quote Top
Old 02-24-2019, 12:18 AM   #7 (permalink)
Photos: 3
Default
I did use the 1/2-28 thread which was not the best choice in retrospect. 1/2-20 or even 1/2-13 would have taken less turns to remove the cap. I was concerned that M12x1.0 would be to small with M10x1.0 section threads. Iím trying to decide which size triple start tap and die I want to get. Until then, Iíll experiment with the other thread sizes first to get a feel for the impact the thread pitch has. Iím trying to find a good balance between all the different diameters of the pen parts, also for when I add a clip and some decorative rings. I still have lots of learning to do but that is the fun part.
Old 02-24-2019, 07:21 AM   #8 (permalink)
Photos: 38
Default
Donít forget that courser pitch threads are deeper and could leave little material between interior threads for your section. I learned the hard way.
__________________
Regards,
Mike
Penultimate is offline   Reply With Quote Top
Old 02-24-2019, 06:38 PM   #9 (permalink)
Photos: 3
Default
Quote:
Yes, Iím aware. That is also the reason Iím trying to decide on a triple start thread size.
Old 02-24-2019, 07:09 PM   #10 (permalink)
magpens's Avatar
Photos: 76
Default
I believe I am correct in saying that a 12 mm triple start will just do it, with a 10 mm section thread ... you could put out a question specifically on this point. . Or you could research some of the similar pen designs in the Show Off Your Pens Forum.
A 13 mm triple start cap to body thread will definitely do it.
For 12 mm, the pitch is usually 0.75 or 0.8 mm. Then the 10 mm section has 10 mm size as the o.d. of the thread (and this would not be t.s.).
A rough rule, for this 12 mm t.s. thread would be that the depth of the thread is very close to the pitch.
So ... 12 mm (o.d. of body thread) - 2 x 0.8 mm (once for each end of the diameter) = 10.4 mm
Subtracting from this the o.d. of the section thread: 10.4 mm - 10 mm = 0.4 mm
Then you have to divide this by 2 to get the "wall thickness" between the two sets of threads = 0.2 mm.
That is really awfully thin and I would be inclined to go for 13 mm t.s. as the cap to body thread.
I don't have as much experience as many others, but that calc. is only intended to give you the idea.
Of course, you have to also consider the overall diameter of the pen (14 mm) and the fact that you have to tap the cap also. . If you go for a 13 mm cap to body, you are going to have a very thin "wall thickness" under the 14 mm overall o.d. . (14 mm - 13 mm) divided by 2 = 0.5 mm and that is OK for the 13 mm choice. . If you do try for a 12 mm cap to body, then you get the same result if you go down to a 13 mm overall pen o.d.
I know that tap and die sets are expensive. . So it would be good if you could borrow a 12 mm tap/die set and give it a try. . It just might work out.
The fact that the 12 mm is triple start whereas the underlying 10 mm is not may work in your favor.
If the pitch is 0.75 mm instead of 0.8 mm that will also work in your favor.
It might be possible to go to a section thread of 9.5 mm instead of 10 mm and that would work.
If I have made any gross error, I hope an expert will correct me.
__________________
Mal
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
