DSallee
Well, here is my latest addition/sale gong to a veterinarian Doctor in Oklahoma... it's a CS USA 10K Retro in Red Mallee Burl ... This is my first Retro and first time turning Red Mallee. The only problem I had with this pen is the fact that I only have a cheap benchtop drill press and after cutting the blank to size it wouldn't fit in the drill press with the 12.5mm bit in place ... that dang 12.5mm drill bit is pretty freaking long! I ended up drilling it on my mini Jet... wasn't for sure if it would work as I had a wobble.... it did egg shape the hole a bit and yea, it was pretty off center so I ended up epoxying the tube in it overnight.
Next problem I had was using the barrel trimmer on them.... the tubes were bigger than my largest trimmer insert... I got it trimmed finally... from there, everything went pretty good...
Special thanks to Ed (Ed4copy) for the tips and suggestions with Red Mallee..
Thanks for looking and any comment or suggestions are welcome...
