More plastic...
See more from YoYoSpin
YoYoSpin
Colorado Springs, Colorado, USA
Craft Supplies Gold Gent Jr. meets Berea Flecked Acrylic
Craft Supplies Plat Gent Jr. with Berea Acrylic
Craft Supplies Gold Gent Jr. with the new CS Celluloid
I'm thinking the gold kit may look best with these new Red/Black/White blanks
wayneis
Okemos, Michigan, USA.
Ed you out do yourself each time you post photo's of your pens. I too like turning the acrylics, I did the yellow with black swirl in a Black Titanium El Grande pen and pencil set and liked the outcome. I just recieved some of the new CSUSA celluloids today and can't wait to get everything finished up that I have going so I can get them on my lathe.
Wayne
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
Ed, you obviously really like turning those "plastics", I have not turned any yet... seems I have this aversion to anything not "natural"... but I think you are beginning to change my mind... I am definately going to have to try some of those materials... LOL
YoYoSpin
For those of you who want to give plastics a try, here are a couple of tips...first and foremost, use scrapers with the burr removed. A "negative rake" scraper is even better. Second, wet sand only...do not dry sand.
I use to struggle with trying to get those tiny scratches and swirls out, and have finally settle in on the following process that works for me on all acrylics, celluloid’s and similar materials: wet sand in 220, 400 and 600 grit increments, then robustly Beall buff with the Tripoli and White Diamond wheels...that's it.
penhead
Local Chapter Leader
Chesapeake, Virginia, USA.
Thanks for the tip Anthony, I just purchased a couple of that pretty yellow/striped acrylic at my local Woodcraft to give it a try this weekend.
JohnPayton
jkirkb94
Oklahoma City, Ok, USA.
As another alternative to Ed's finishing, I have been using the Pen Finishing Kit from Woodcraft (product #143186, also available from other sources) for a while. I usually skip the 1st 2 grits and wet sand with the rest. I dip the pad in water and try to keep some of the water cupped in the pad as I use it. Refreshing the water once or twice with each pad. If I miss some scratches I go back and start again and am more agressive with the lower grits if necessary. I recently bought some MM in pads from 1500 to 12000 and will be trying them. I need to try your advice, Ed, and get a scraper. Do you have a link to one of the "negative rake" scrapers? Kirk [8D]
