A while back someone made a post about modifying a cigar.I like to make the "kits" appear different from others.
One thing that impresses me about the cigar pen is the amount of"parts" you get for so little cost.
The thing that I dislike about the cigar pen is it is a difficult one to modify.(Unlike the slimline)I started playing around and trying to see how much can be removed without changing the function of the pen and still change the appearance.
The lower tube needs to be lengthened(or buy lenghts and cut your own) if you remove the small black trim ring on the bottom.
I purposely made this a BIG one to show the pattern of the glue up.I'll have to live with the bad joint.
Because we now have a "critique" forum I would appreciate your remarks there as to what you don't care for in this piece .
