Mini-Twist Pens
See more from KKingery
KKingery
De Pere, Wisconsin, USA.
Here's a couple of mini-twist pens I finished today.
Mini-Twist in Cocobolo
Mini-Twist in Dyed Chestnut
tipusnr
Reynoldsburg, OH, USA.
I'll have to look at these kits again - yours are done well. I've made a few pendent pens and didn't like the way the refills were installed. Maybe these are different.
KKingery
These are the kits from CSUSA. I imagine the refills are the same - they screw into the top of the transmission. I just thought I'd try something a little different.
ctEaglesc
Passed Away Jul 4, 2008
Camden, S.C., USA.
How hard is it to get refills for them?
I don't recall seeing them at office stores, but then again I had no reason to look.
opfoto
Albany, NY, USA
Nice looking pen.... The finish is great, notice how the hot spot from the flash is almost the exact same width from wood-CB-wood. Nice job Ken. What did you change in your finishing technique (if I may ask)??
KKingery
In the last week or so, I've changed a couple of things. First, I slowed down my lathe. I now turn, sand & finish at 1300rpm. I was sanding at 150, 220, 320, 400, 500, 600, 800, 1500 & 2000 grits. I now sand at 150, added in a 180 grit, and dropped the 1500 & 2000 grits completely. In addition, I now add sanding sealer between 220 & 320 grits, and then again between 400 & 500. I've also starting using the MM (1500 thru 12000). I've stopped using paper towels completely for any finishing, other than just wiping down the blanks between sandings. I use old cut up socks now to apply the EEE, and the Minwax paste finishing wax if that's what I decide to use. If I don't use the wax, I now use the Deft spray laquer. Not big changes, but enough that I've seen better finished results.
