Manu Propria Pens - Tame-Oshidashi-Nuri
See more from manupropria
manupropria
Bern, Switzerland
A month ago I started working on this lacquer. Some remember an earlier post showing the pens after applying metal powders in pattern on the pen parts This is what turns out after 30 layers of transparent urushi. The lacquer I call "tame-oshidashi-nuri". With the time the various pattern, material and colors will appear more and more because thetransparent lacquer will get more transparent.
Best regards,
Martin
leehljp
Member Liaison
Tunica, Mississippi,
Martin,
About 30 days for the process? Do you usually allow for 1 day per layer of lacquer? I know that you work on many pens at simultaneously but the process takes considerable time, and it is well worth the effort.
Beautiful finish. Thank you for posting these and thanks for that last picture. It clarifies your process. 本当に、どうもありがとうございます。
Charlie_W
Sterling, VA USA
Absolutely Splendid work as usual Martin!
I too like the last pic showing the pen parts before lacquer. The texture is wild!
Also, wonderful shop space with the natural light.
SteveG
Eugene, Oregon 97404
Somehow you manage to outdo prior efforts which I felt were the very pinnacle of what could be done. The word penultimate comes to mind (which allows for 'pun intended' :biggrin:), in that you manage to push your artful work a step further with your latest effort, making the previous design the penultimate one. I think I understand how you accomplish this, in that you posses unbounded artistic talent, and are unwilling to let that ability become stagnant. So 'BRAVO!!' on this latest! :) :)
manupropria
Bern, Switzerland
To flattering. here some pictures of my lovely atelier. I am very sure, that making nice things can only be made in a nice place.
I had the chance to set up my ateler in an old black powder factory from the turn of the century. It is a very inspiring place
magpens
Canada
Attractive, Inspiring, and Impressive !!!! ... that would have been the turn of the 20th Century !!!!
SteveG
Martin, thanks for the add'l photos of the inspiring work place...it does seem conducive to creating beautiful results. That has proven true by the outcome, as seen in your work. Aloha!
Skie_M
Lawton, Ok
The Urushi is a sap ... generally somewhat toxic. This sap is closely related to the sap from Poison Oak, and in fact you could actually use Poison Oak sap for a lacquer.
Lacquer is thinned with ethyl alcohol, rather than water, but you can use standard types of acrylic dyes to color it. The more dye you add, the longer it will take to properly cure and the softer the item would be, so less is better.... if you want the color darker or more pronounced, you simply add another layer! :)
The lacquer cures in the presence of heat and moisture ... most lacquer masters in japan refer to their lacquer workshop as their "bathroom" .... simply because the lacquer would cure best in that type of environment. Once cured, the lacquer is waterproof, hard, and non-toxic.... (well, it should be non-toxic in most cases, though the wet lacquer is toxic).
I'm going to have to see if Hobby Lobby carries any kind of Urushi lacquer... it seems to be something that would bring beauty not just in the present, but for many years to come .... :)
manupropria
Bern, Switzerland
Thank you Skie for the explanation.
Maybe some corrections.
Urushi is a very aggressive product. Only a few natural pigments can be used to color urushi. Blue for example can only be mixed with Prussian Blue or Indigo. All other pigments turn the urushi gray. Same with other pigments. Lately also some chemical pigments were develpoped to color urushi.
Serious lacquer artists only thin urushi with caphor or linseed oil and only for "nuritate", final coat without polishing. I only use de best Japanese urushi which is extrelemy liquid and transparent, therefore I even don't need oil for nuritate. 90% of urushi used in Japan is Chinese and much cheaper but also more sticky and darker than Japanese urushi. Oil is weakening the urushi. In the industry urushi is often thinned with various chemicals and sprayed, mostly 20% urushi and 80% chemicals
