Manu Propria Pens - Namban Kawarinuri
See more from manupropria
manupropria
Bern, Switzerland
A "Shibui" Type ebonite pen with a urushi lacquer I call "Namban-Kawari-Nuri".
Kawarinuri is the term for "experimental Lacquer".
Namban = Southern Barbarian, designs influenced by or made for foreign market. Many thin rings of urushi are applied with a brush and sprinkled with a wide range of metal, eggshell, mother of perl and dry lacquer powder. After applying many layers of transparent lacquer the surface is ground flat and polished.
With the time the transparent lacquer will become more transparent and the underlaying colors will appear stronger and stronger
Curly
Saskatoon SK., Canada.
Martin the pen is great.
I'm curious about the Urushi getting lighter in time. Does that happen when kept in the light or when kept in the dark too? Thanks.
manupropria
Bern, Switzerland
Thank you very much.
Urushi is let's say 98% cured when polished but over the years it cures completely and reaches a haardness of glass Mohs scale 4 and it becomes more transparent. It is a chemical reaction and if it is kept in daark or light does not affect this process
OZturner
Sydney. NSW. Australia
Stunning Pen Martin,
Your usual Perfect Profile and Proportions.
Great Turning, and Machining.
Exceptional Kawarinuri Finish, and Polishing.
Masterful as Usual.
Congratulations,
Brian.
