manupropria
Since a while I was thinking about a practical anddifferent clip to be used on my urushi fountain pens.
Since my pens are rather large, regular clips cannot do.
This is a clip that is glued directly on the cap. The glue is urushi lacquer and a very strong adhesive also used for "Kintsugi" mending broken porcelain.
The clip is cast in Beryllium bronze. This special alloy can be hardened after finishing to a hardness of Vickers 140, almost as hard as steel.
In the same time it can be used as a clip and as a stoper.
It took a lot of experimenting to find the riht shape.
I wanted the clip to look like an origane (soritsuno, kaeritsuno are some of the alternative names) - a small hook that fastened onto the underside of the obi (sash) and kept the sword saya from moving around too much when drawn. They were not used universally - presumably to the owner's taste, and were more common on wakizashi than on longer swords.
Best regards,
Martin
Best regards,
Martin
