Mango flavored Cigar Slim
See more from Drstrangefart
Drstrangefart
Woodstock, Ga. U.S.A.
This one is for the guy that got my first Cigar Slim. That one wound up with a buttload of problems, mainly part of the label breaking off from air being under it. Acid brand labels are NOT SUITABLE for these projects. I fixed the other issues with fit and function, but I figured I'd be happier letting him keep the prototype and getting him one done RIGHT if he's gonna pay me for it. I added a clip per his request in order to make it easy to carry. Hopefully there won't be any more problems with it for him. The label was easy to work because it's a simple shape on thin paper. Got it covered and done a lot faster. An hour or so start to finish, maybe more. Thick CA passed back and forth directly on top of the label sped things up a LOT. Managed to get a good base by sanding it with 400 grit after a lot was built up. The rest was pretty easy after that, sadly I had some floaters in the CA near the label for some reason.
alphageek
Former Moderator
Green Bay, WI, USA.
Nice learnings in that paragraph, but still one unanswered question.....
mango flavored?? :)
I guess. It's mango wood as far as I know. Probably tasted a little like mango before I added 40 or so layers of CA. Smelled pleasant enough.
It sure LOOKS like mango to me... I just have never actually decided to taste the stuff to see if it tastes like mangos.:biggrin:
ToddMR
Columbus, OH
Good job on the pen. That was a nice piece of wood to use for that specific style too. I think it looks really good. And OMG that's a lot of CA. hehe
Drstrangefart
When you going to toss the clip and close that end?
Nice CA finish on this one!!!
Scott (it's a good un) B
This is the first one I did with a clip, and that was because this is intended to be carried daily. When taxes come in I plan on investing in closed end parts and stuff to do fountain pens. Besides, at least I found a way to do these for a total cost of about $5 with stuff I apready had. That's gotta count for something.
Drstrangefart
Yeah, it's a lot of coats. Between the thinner paper, and doing about 5 or 6 coats of thick directly on top of tha label when I started, I was able to move it along with fewer headaches and less time.
SDB777
Cabot, Arkansas USA
Whoa....$5 counts for a LOT!!
And the practice your getting on the stoogies....thumbs up!
Will the clip take the exact 'strain' from use since it's already being pulled out so much?
Scott (hope so) B
Drstrangefart
Scott (hope so) B
I'm thinking the clip will hold up, I've had the Fancy Slim clips take LOTS of abuse being carried at work and haven't run into major issues so far. This guy is in school to become a barber and this one SHOULD be well cared for during its lifetime.
