tipusnr
The latest pen in my photo album is not the most artistic I've ever done but it did open new ground for me. While I have been turning my center bands for awhile now last night I tried turning the plug for the top.
The hardest part was getting the stock to run true in my Talon Chuck so I could turn the plug off the end of the stock. I bought some slimline kits last winter that the clip assembly was a three piece set (collar that hides inside the brass pen tube, clip with thin washer top, and male plug to go inside the collar sandwiching the clip). One of the drawbacks to this was that you still had a hole in the top of the pen when you were through.
The plug I turned needed to have a very thin tenon (around 1/8") to go inside the pen and then a turned top for looks. The original plug as it left the lathe was more of a mushroom shape than you see in the picture but got flattened out as I attempting the sanding and polishing part. I'm not used to working that small and it took quite some time. Still the result was satisfying. Mine's a friction fit but was perfectly willing to glue it if necessary.
Try it yourself. It just adds one more way for the pen to be out of the ordinary.
The centerband is tapered so that I could have different diameters on the top and bottom. There are also two grooved bands in both the upper and lower blanks to break up the lines and give detail. With this type of corian you don't notice them until your fingers hit them and make you take a second look.
I'm thinking of filling the grooves with contrasting material in the future for more visual effect.
Sorry, I didn't do much to pretty up the picture as time is short right now. Also found that it overfilled my screen when clicked but clicking the "maximize" button on the window solved that for me.
Let me know what you think?
