Long Boy Silver Tiger
See more from qquake
qquake
Northern California
This is a new kit from Berea in gunmetal, called (appropriately enough) Long Boy. The blank is an acrylic from Beartooth Woods called Silver Tiger. I like the kit, not too sure about the blank.
qquake
Northern California
The size of the Long Boy is deceiving, because it's so, well, long. It's thicker than it looks, it uses 10mm tubes. Here is a size comparison with an Executive.
qquake
Northern California
This is an unusual blank. At first I thought the epoxy was showing through. But if you look closely, there are "ripples" in some of the colors. Don't know what caused it, and I've never seen it before.
magpens
Canada
Well done !!! . Do you think the Long Boy could be made with a single long barrel ? ... assuming I can drill straight for the whole length.
qquake
Northern California
I suppose theoretically it's possible. Berea sells 10" long lengths of 10mm brass tubes.
10 inch long 10mm Brass Tubes 10 Pack: Pen Kit Making Supplies Berea HardWoods
But drilling the blank might be problematic. The body is just a hair under 4" long. I think the hardest part would be finding a 10mm drill bit long enough. The 10mm bit I have is 5-1/8" long overall, so it might be possible.
Brian G
Bloomington, MN
I bought some when Berea introduced them on their website. I've assembled three. I found the click mechanism a little fussy to assemble, but it's easy overall.
If you press the center coupler into the upper and lower tubes, then turn the coupler flush with the tubes, you won't need to purchase separate tubes.
Your pen looks nice.
