Cincelaser
I was searching in the forum but I can find any info about dyed CA, so I made a little experiment this afternoon.
By request, my friend and IAP member Lane223 send me some wood tubes for my laser engraving experiments (I own a lathe but not tools to work and experience still), so I engraved those tubes and painted one of them with metalic acrylic paint, let dry and applied a lot o CA coats. Sanding and polishing did the rest (first attached image) but I don't like the result so much, you can't appreciate the metalic effect.
For the second attempt I mixed medium CA with Inlace Metallic Blue dye to fill the engraving with good results. Rotating the pen in your hands you can see the same metallic reflections that you are accustomed to seeing in any metallic resin blanks.
I'm sure that there is a way to do the same with less work!
