JD Combs Sr
For your critique here is a Pen made not from a kit. Although I did used some components from a kit. I modified and used the the click mechanism and finial/clip assembly from a SlimLine Pro. Other components were purchased separately and modified as necessary.
Specs:
Lower Barrel:
30-06 Cartridge with 155.5 Grain match grade FMJ bullet.
Sanded to 1800 then polished to a high gloss with Brasso
2-3 Coats of CA applied to prevent tarnish
Parker Style Gel Writer Ink Cartridge.
Upper Barrel:
Buckeye Natural Burl with Gun Metal Clip and Finial
10 Coats of CA and Polished with plastic/acrylic polish then waxed
It's not quite as obvious in the photos but the natural buckeye almost looks like a type of camouflage.
This shows some of the inner components that were modified.
Does any one know where I could find a nut similar to the one I cut off of the 8mm tranny?? I salvaged the tranny part, not sure what I can use it for but something will probably turn up.
Specs:
Lower Barrel:
Upper Barrel:
