maxman400
OK my first Kit-less weighed in at 130 grams, so Skiprat said I needed to work on making them lighter so here is my second Kit-less, Slim, Ball point, Something or another. I started with a 5/16" X 1 1/2" stainless bolt and turned and drilled it to make the nib. Then I used 1/2" aluminum bar stock, drilled it and tapped it to accept the 5/16" nib and a cross refill with a spring behind it like a roller ball. The Cap is 1/2" bar stock drilled and tapped, both the cap and body is tapered at 4 degrees. Total Weight 31.8 grams.
Thanks For Looking, Any comments welcome. :biggrin:
