I have been experimenting with a new finish process (new to me, and with the help of some selfless IAP members) in my quest to eliminate wet sanding and MM (just because I find it boring to wet sand and I don't like introducing water to a CA finish).
So here is the process:
Comments, questions, platitudes, criticisms, and good ol' fashioned negativity, just for the heck of it all welcomed.
Thanks for looking and hopefully, laughing!
- Skew turned
- Dry sanded 400 to 600 (at 700 RPM in reverse), Abranet
- Clean with a squirt/short spray of CA accel on a ppr towel or cotton tshirt material, then apply to forward, and slowly rotating barrels.
- Apply 10 coats of thin CA, no accelerator between coats, and one or two coats of medium, with short spray of accelerator after each medium coat only. Let sit for a few hours (like 3).
- Sand from 400 to 600 dry, same as before CA finish was applied as in Step 2..
- Cotton Flannel buffing wheels at 1,000 rpms, Caswell's white diamond (or any WD), ultra fine compound, then fine compound (No, you read that correctly. Caswell's ultra-fine is more course than their fine. I guess their product naming isn't hurting sales..so they keep the names ).
- Lastly, as always and not really necessary, Meguiars 105, 205, and Rejex (and yes, I am sure there's water in all of them..unless Meguiar's invented a new form of matter than can be poured and assumes the shape of its container).
