LL Woodworks
This was an exercise in futility and am elated that it made the top ten then placing 5th in the polling, my appreciation goes to anyone that voted for this pen. It is a Triton BP kit from Beartooth Woods, originally a chrome plated kit with gold accent CB and finial. Let's start with the upper barrel.
It is made with alternating vertical segments of white oak and eucalyptus burl with thin (.005") aluminum separators (soft drink can aluminum); then framed at the top and bottom with African Blood wood horizontal segments. I was disappointed that the contrast between the white oak and eucalyptus burl wasn't more pronounced. So disappointed in fact that I sat on this blank for about two weeks before deciding to go forward with it. Here is an other conundrum; the CB and custom finial are made from the same piece of eucalyptus burl as the segments in the upper The upper segments were suppose to have the look and contrast like the CB and finial???
Now the lower. The initial design was for lower barrel to match the upper barrel. Alternating vertical segments, framed at the top and bottom with horizontal segments of blood wood. After spending hours making the blanks, the drill some how drifted off center ever so slightly (the top drilled fairly straight). Naturally, when it was turned the segments were not parallel, so trash that effort.
I seriously considered trashing the entire project but had to much time invested in the making of the blank; back to the drawing board. So the lower barrel became the simple eucalyptus burl that you see here. All in all it turned out OK but far from what I had envisioned and really wanted and I'm extremely pleased that it made the cut from 49 to 10.
Thanks for looking
Thanks for looking
