That is an excellent pen! Very nice. I will have to try the Imperial.
If there is any chance of the glue or tube showing thru, I spray paint the Inside of the blank. This keeps the glue and brass tube from showing thru. I can also change the color by painting the inside of the tube a different color.
Very nice work Ian, as I said in the email to you I had no problem for around a year, I had painted the tubes etc.. It was the glue that turned brown over time and this can be seen through the blank.
Next time I do it, I will mix a little white nail varnish into the glue to colour it white too.
Ian I pinched it from your make-up bag! lol
I forgot to mention that the tube was sprayed white with automotive paint. I like the idea of spraying the inside of the tube a different colour. The result could be very interesting.:wink:
Ian
