Ignore the optical illusion...
See more from Marc Phillips
Marc Phillips
Columbus, GA, USA.
No, the centerband is not cut at an angle... no clue what is going on here, but with the new computer came a different version of my old software I used on the old computer... all I did was load the same program but it works differently on the new computer..
Oh well...
It's a chrome Euro with Juniper and a spalted ash centerband...
I am using the new 3" tool rest from Randy at Monster Tool www.monster-wood-tool.com ... works like a champ. Nice to be able to get the rest close again...
I also used my new bushings from JohnnyCNC
http://penturners.org/forum/topic.asp?TOPIC_ID=35046 ... so I can turn Euro's between centers... Nice... I am totally hooked on turning pens between centers now... just seems so much better and easier than using a mandrel..
Moving along... this one was my first try at making my own centerband on a Euro... didn't get the proportions the way I would like, but hey, it's a first pen... I am either going to make the lower barrel larger or taper the upper barrel a little so that there is less of a drastic diameter change between barrels... and I needed to round the centerband a little too... Learning lots by doing!
Dalecamino
Local Chapter Leader
Indianapolis, In.
Marc , you've already said everything for me ! This is a beautiful pen now ! With your notes , it would really be nice ! The finish is smooooth . What did you use ? I like the CB ! Thanks for sharing ! [8D]
Marc Phillips
Columbus, GA, USA.
Thanks...
I use a Ca finish... no blo, just thin CA sanded through 12000 MM and then on to the Beall buff...
Randy_
Dallas suburb, Texas, USA.
Originally posted by Marc Phillips
.....I am either going to make the lower barrel larger or taper the upper barrel a little so that there is less of a drastic diameter change between barrels...and I needed to round the centerband a little too...
Good thinking!! I had the exact same reaction when I saw the picture.
Marc Phillips
Columbus, GA, USA.
Thanks all... it did throw me off doing one blank at a time with the Euro... even though all I had to do was take the blanks off and compare them before starting the finishing! .... Doh! [:p]
toolcrazy
Port Orchard, WA
Originally posted by Rifleman1776
Doesn't do it for me. Center band looks like a mistake or afterthought. The CB should have a rounded bottom to help blend with rest of pen, looks unfinished. Sorry.
Sorry, but I agree. The rest of the pen looks very nice, but the CB.......
