Butch, I tried a light coat of adhesive, but I could not get the carbon fiber to slide over the tube with out sticking, pulling, wadding up and just plain not cooperating,lol.
Steve, I put a waxed 1/2 in. dia. steel pin in the end of the c.f. sleeve and ca glued a bead around the tube. When it dried I pulled out the pin and inserted the brass tube and put glue 1/2 inch past tube and cut there when it dried. I then painted the c.f. with a thin coat of casting resin and let it cure. Then into mold and full cast of resin. Fixture I am building will hold c.f. sleeve tight with several tubs inside so I can make sure weave is straight and paint with resin and hold it until resin cures, then trim tubes and I can cast. It should work. If it does, I will write a "how to" with pictures.
