Hi Jim. Are you using a sleeve in the lower barrel? Without it is not turning to produce the refill a bit tight?
I have been using the replacement tubes from a purfume applicator that are just a smidge larger ID hat the 7mm OD. You only need an inch or so at the nib end.
Fun stuff eh?
