Tom McMillan
I've made pens with a Cross for a number of years. But, different than some I've seen here---I've always put the cross on the lower barrel. I made wider Crosses before I moved since I used a radial arm saw then to cut the slot for the inlay. Now, I use a bandsaw to cut the groove and can use a much thinner inlay. I've attached a photo of 4 (sorry, the photos not too great). On each end is a Kingwood pen with a brass Cross (if you make any with a metal cross--do be careful---I've had some come loose when turning and they can fly out at ya), and the middle two are maple with a Bloodwood Cross and maple with an Ebony Cross. Also, I did make a wedding set for my youngest daughter with a heart shaped base of Bloodwood and 2 matching pens of Bloodwood with maple Crosses.
