Glass Nib Dip Pen
See more from BRobbins629
BRobbins629
Passed Away Dec 28, 2021
Richmond, VA, USA.
Started to play a little with glass and figured why not make a few nibs. Most write pretty well, but made need a little smoothing. Was able to fit one in an existing section I had just to try it out. May even be able to use with a convertor if I can seal everything off. Plenty of things to try, but here is my first. Here's a picture of the pen as well as some of the first batch of nibs.
attachment.php
attachment.php
ChrisN
Denver, PA
Very creative! I'd be afraid of breakage, though. Did you make any flex nibs?:tongue::tongue:
Charlie_W
Sterling, VA USA
Bruce,
It is very "clear" that you are going to generate a bit of interest with this nib!
The pen is top notch as well. Keep us updated with your progress.
PenMan1
Eatonton, Georgia
You dog, you! I knew somebody would beat me to this! Nicely Done!
I've been trying for a WHILE. I've made a few pretty ones, but none that ACTUALLY WRITE!
Congratulations. Quite an accomplishment!!!!
PenMan1
Eatonton, Georgia
If you can make one that uses a cartridge or converter and leave the writer with clean hands, you will indeed be a pen wizard!
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
Very nicely done Bruce !! It has been years since we saw glass nibs being shown here. Weren't you also involved with it way back then?
Don't listen to Glenn !! In fact you need to take a break for a while !!:wink::tongue:
I think a month should do it!!:biggrin:
BRobbins629
Richmond, VA, USA.
Thanks to all who commented.
Cool Bruce! Is the flow regulated somehow?
The flow is dependent on the width of the tip. Some of the ones I made are fine and some are broad. I have yet to start grinding or smoothing, but I think that would be the way to regulate flow. Also possible that some positions change flow.
This are my first Skip. Just getting started.
