Formica Solid and Walnut Slimline
See more from saftrep
saftrep
Foxworth, Ms.
Discontinued Copper Formica solid with Curly walnut.
saftrep
Foxworth, Ms.
Appreciate the comment. I used a CA finish on the walnut (Danish oil, two coats thin CA, 400 grit, two coats cellulose sanding sealer, 2 coats thin CA, two coats thick CA, 150, 240, 320, 400 grit, micro mesh 1500 thru 120000. Meguiar's scratch X (yep, works for me) The Formica top was run thru the grits, micro through 12000 then the the scratch X.
