first use of my squareing jig
See more from chartle
chartle
Pgh, PA
My squareing jig worked.
chartle
Pgh, PA
Its bloodwood with maple and locally sourced walnut from around my area.
My father hung out with a tree trimmer that would cut the fallen trees into lumber. My father used to help him out and his payment was wood.
As I was getting close to finished size I lost a piece. :eek:
I had what I thought was a catch and I saw the piece pop out and land on my gouge. It then fell to the bench. I didn't panic since I saw it fall and i found it under the lathe.
I reglued it and then soaked the rest of the inlay with thin CA. I probably should have used at least Epoxy to glue in the blank, coating the inlay inside the blank and also probably used epoxy for the inserts. I was in a rush and needed some instant gratification.
Here is a link to the sled that Spanx is talking about.
http://www.penturners.org/forum/f30/celtic-knot-squaring-jig-132105/
