First two Imperials
See more from leehljp
leehljp
Member Liaison
Tunica, Mississippi,
My first two Imperial RBs. I am a little surprised by the photos. They seem to make the pen barrel section look slimmer in the middle. I guess what takes me back is the care that I took on these two pens in using the calipers. I have never taken the time to make it perfect in size from one end to the other and matching the fitting diameters to a .000 tolerance.
These two are for the fathers of a couple on our team. Normally, I would charge 3 to 4 times the base cost, but in this case, the couple were hand picked by us. They work the the way everyone _dreams_ for a "team" to work. So I can only charge the cost of the pens.
These were a joy to make!
The Amboyna was made from 3/4 inch stock and I was a little skeptical if I could do it. However, I drilled the hole on the lathe and it worked fine.
The Ebony is not nearly as dark once outdoors as it appears in the photo. Inside, it does appear all black, but outdoors lots of dark brown streaks are readily visible.
CA finished. Only sneezed twice from CA fumes and dust. Dust Collector, mask and gloves used extensively.
johnnycnc
columbus, IN, USA.
Wonderful pens,Hank.:)
Your time and care shows in the photos.
You did an outstanding job on both,
I'm sure the recipients will be thrilled!
Randy_
Dallas suburb, Texas, USA.
Very nice work. I really like the ebony version!!
Did you use true ebony or one of the look-a-likes?? Since ebony has a rep for cracking, did you do anything special in an effort to reduce the possibility??
leehljp
Member Liaison
Randy,
I used Japanese persimmon - which is classified as an ebony. No I did not do anything special to it. It has been in a 7/8 by 7/8 stock for 6 years, so aging should be fine. On the ebony pen, I drilled it, waited a few days, glued with epoxy and waited about a week before turning it. Then I finished it - one coat and one sanding at a time, about twice a week over 3 weeks. It had a fair amount of time to settle. But that in itself won't always stop the cracking.
Time will tell. The owner has a standing offer for fixing it if it does crack. The owner (to whom it is going) is a person I know well and he does take good care of things like this. It won't be abused either physically or in heat/humidity extremes. This will be a good test.
