Jim Haslett
So, this is my first attempt at inlay. I'm happy with the way the inlay turned out. It was quite a bit of work getting all fitting correctly.
This is a copper "Classic American" kit from Woodcraft, with cocobolo and padauk inlay. It has a BLO/CA finish.
I ended up losing the lower pen tube, and it cracked as I re-glued it together. I also ended up with a defective transmission. It is a double twist mechanism, but it won't stay extended. No matter how hard you twist in either direction, it just retracts automatically.
This is my second try with this kit, and I'm haven't been happy with either of them. The first one I had issues getting the transmission to "lock" into the upper part of the pen. I also like a pretty hefty taper on the lower pen body, and this kit doesn't really allow for that because of the way the middle band overlaps the lower body.
I'm more or less happy with the finish. I'm starting to get the hang of it.
So the pen itself is not a good finished product, but it was more about testing the inlay process and practicing my technique. I am happy with the inlay and I'll definitely do it again. I also practiced measuring the pen components and turning to dimensions, instead of relying on bushings.
