Gilrock
I just joined IAP a week ago and I've only been turning pens a couple months. After browsing all the wonderful posts here I decided to try a couple segmented pens. The first pen was a Cambridge and has 3 different acrylic colors seperated by a butchered diet coke can....not really the colors I wanted but the best I could pick out at Woodcraft since I was anxious to start one. I wish I had darkened the tube/blank since the brass is showing thru one of the colors.
The second pen was a Cigar and I used a piece of Elk Antler I had lying around along with what I believe is Ebony wood. There was supposed to be antler on the bottom half but it cracked while drilling. And then I was in a hurry so I tried to quickly cut/drill/glue the wood on the lower tube and it got stuck partway in. So I had to square off the wood on the lathe and created the segmented section on the bottom half. And I had pieces coming apart from the aluminum on the top half while drilling so the seams don't look as perfect as I would like.
Overall I'm happy with how they turned out for my first attempts at segmenting. And I'm loving all the pens I'm seeing from everyone here.
Thanks for looking,
Gil
Thanks for looking,
Gil
