First segmented pen and others
See more from armyturner
armyturner
Oil Trough, AR, USA.
Here are a few from the last couple of days. First is my first attempt at a segmented pen. It is a chrome sierra with black walnut and purpleheart. I wanted to keep it simple.
Second is a black chrome sketch pencil in bubinga. I finished it with several coats of myland's sanding sealer, hut ppp, and renaissance wax. I heated the beads up while applying the ppp in order to darken them.
Last is a 300 WSM casing with macassar(?) ebony upper barrel. The 300 WSM casing is considerably larger in diameter than a 308 Winchester and almost an exact fit in length for a slimline tube. It gives it a little more heft and when finished is similar in size to a cigar pen.
If anyone is intrested in some 300 WSM, 308, or 30-30 casings with tubes installed let me know and I will put some together and list them. I am also waiting on some clear powder to come in. After the trial and error period I will try to start listing some clear powder coated casings.
