Gary Beasley
I've been doing a bit of research and got the toys together to try this out. I sat down this afternoon with the polymer clay and pasta roller and made a cane with this pattern.
After applying the slices I baked it the recommended time and temperature, but the blank was a bit softer than I anticipated. Even after giving it an hour of cool time it was not as hard as even a relatively soft polymer casting. Is this usual or do I need to modify the baking routine to get a harder result?
Because of the softness I CA coated it after I turned and sanded it with the usual micromesh finishing.
