First Kitless Pens
See more from mrplace
mrplace
The Colony, Texas, USA.
Here are the first two kitless pens that turned out satisfactorily. Cap threads are multi-lead, and the nibs are Reform nibs from Elliot's. I have some design changes in mind for the next one.
It is nice not to be dependent on kits, but to be honest, nibs are not cheap either.[:p];)
Firefyter-emt
Putnam, Connecticut, USA.
Very cool, are you planning to share your threading trick? I would love try that! How does his nibs attach, are they a press in thread fitting? How do you fill the pen, dropper maybe?? [:D]
mrplace
Originally posted by Firefyter-emt
<br />Very cool, are you planning to share your threading trick? I would love try that! How does his nibs attach, are they a press in thread fitting? How do you fill the pen, dropper maybe?? [:D]
Threads where not a trick. I have a metal lathe and a mill. It has took me since early March to learn enough to get to this point, and I have more to learn. Threading is not as hard as expected, took less than a week to actually work all the kinks out.
The nib front section is threaded so there is internal threads cut in to the body. Elliot also sends a brass insert that can be used. These fill with a premium pump or you can use a cartridge (which I use).
I do have to give credit to Dan and Bruce for answering many, many questions I had along the way.[:)]
Stevej72
Billings, MT, USA.
Excellent work! I've been working with my metal lathe for a couple months now, but still haven't turned any threads. Hope to get that good someday. Thanks for sharing.
Firefyter-emt
Thanks for the heads up! Did you cut the cap threads on the lathe too?? I am impressed!
I seriously should think about getting a modern metal lathe, there is just so much you can do with cool things like power feed and good adjustments! [:D]
Milpaul
Milwaukee, WI.
Great work! Besides not depending on the kits, you are also not confined to an exact length or diameter of a kit. You now have a lot more options (like you haven't already been thinking about that!) [:p] [:p]
xylostyle
Winters, CA, USA.
Excellent work Ralph. I used to do triple lead threads with a CNC lathe. I always admired people that could do what you did on a simple hand lathe.
Elliot
