First Celtic knot - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Show Off Your Pens!
  Forgot Password
Show Off Your Pens! Let's see your best work!
Welcome to penturners.org!
Reply
Old 07-31-2014, 12:42 AM   #1 (permalink)
Photos: 0
Default First Celtic knot
Here is a picture of the good side of the first Celtic knot I have done. the other side is off slightly but I learned that I need to make sure everything is lined up when doing the glue up each time. I also learned that it is very important to have the blank square and the ends of the blank squared up as well.
Nate
__________________
Nate
I am not what I want to be. But still, I am not what I used to be. And by the grace of God, I am what I am. John Newton
nates02gt is offline   Reply With Quote Top
Old 07-31-2014, 01:15 AM   #2 (permalink)
BW Design Works's Avatar
Photos: 13
Default
Looks good! Goes nice with that kit as well. Keep at it, we all learn things from repeating the process over and over.
__________________
Bryon
BW Design Works
www.bwdesignworks.com
BW Design Works is offline   Reply With Quote Top
Old 07-31-2014, 02:12 PM   #3 (permalink)
Photos: 38
Default
looks good.do you cut all the way through the blank. another thing to check is make sure your blade is set to 90 degrees
dogrunner is offline   Reply With Quote Top
Advertisement
Old 07-31-2014, 08:14 PM   #4 (permalink)
Photos: 0
Default
I tried both cutting all the way through and not cutting all the way through. I saw a video on Youtube that showed the guy cutting almost all the way through, leaving about 1/16" or less, so i tried that first. Due to the width of the kerf and the width of the inlay, I was getting a 'bent' blank without cutting all the way through, so it seems like cutting all the way through is better. I did all my cuts on the band saw. I set the table at 45 degrees and clamp a stop block to the miter gauge. I haven't built a sled for my table saw yet to be able to accurately and safely cut the blanks on the table saw. Any advice or input is greatly appreciated.
__________________
Nate
Old 07-31-2014, 08:32 PM   #5 (permalink)
mark james's Avatar
Photos: 484
Default
Your knot (this side ) looks great!
But shoot... A Celtic Knot on a Southwestern Theme Pen Kit .
OK, I love both actually! But... maybe on the Celtic Theme kits!
Just me!
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 07-31-2014, 08:55 PM   #6 (permalink)
Janster's Avatar
Photos: 16
Default
....nice knot! Well done......Jan
__________________
Use it up or wear it out, make it do or do without!
Always keep your words soft and sweet, just in
case you have to eat them.
Janster is offline   Reply With Quote Top
Old 07-31-2014, 10:38 PM   #7 (permalink)
Photos: 38
Default
your inlay needs to match the kerf of what ever blade your using. even when you cut all the way through when you glue your first inlay in the blank gets longer if your inlay is thicker than your kerf thats what throwing of you knot.cutting them on the table saw for me is a lot easier its worth the effort of building a slead.i also like a 55 degree angle or more makes the knot a little bigger hopes this helps anyother ?don't be afraid to ask
Old 07-31-2014, 11:29 PM   #8 (permalink)
Photos: 0
Default
mark james: I dubbed it the 'diversity pen'. I made it to go with a journal I brought back from Afghanistan for my sister-in-law. =)
dogrunner: Thanks for the tips! I was unaware of the kerf 'rule' but it does make sense. did you make a sled specifically for pen blanks or do you have a general crosscut sled you use? I will have to try the 55 degrees and see how that looks.
Nate
__________________
Nate
Old 07-31-2014, 11:43 PM   #9 (permalink)
Photos: 38
Default
yeah I just use it for pens the hardest part of making one is getting the runners to fit right in the slots look at the post blue grey oak virage if you want to see what a 55 degree knot looks like
Old 07-31-2014, 11:50 PM   #10 (permalink)
Photos: 0
Default
dogrunner: That looks pretty awesome! I picked up some aluminum sheeting at HD the other day and plan on trying it this weekend hopefully. Do you happen to have a picture of the sled you made?
Nate
__________________
Nate
Related Content
Reply
Bookmarks
Tags
celtic knot , segmented pen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
