First Carbon Fiber
See more from Sylvanite
Sylvanite
After seeing David's (a.k.a. theidlemind), post "carbon fiber how-to", I decided to give it a try. I ordered a small assortment of carbon fiber and carbon fiber/fiberglass sleeves and my wife picked out this color (after complaining that it looked like a box of snakes).
attachment.php
attachment.php
I was impatient to try it, so I simply painted the tube, glued on the sleeve, and then did a CA buildup. I guess I'll just have to find another excuse to break out the casting resins.
I hope you like it,
Eric
How layers of CA did you need to put on this one? Is it completely smooth, as if it was PR cast?
I didn't count the layers - probably somewhere around 25. I built the blank up to just over 0.500" diameter and then turned it back down to 0.475". After sanding and polishing, it is completely smooth and indistinguishable from cast.
Regards,
Eric
