jbostian
After a successful first attempt at a cigar pen yesteday, I decided I needed to try something else for the first time. I had been wanting to try to do the CA finish and my order of glue just happened to arrive today, so I thought I would give it a try. I decided to make a slimline that way if I totally mess it up I wouldn't mess up a nicer kit. I also decided to make my own wood centerband and make the pen a little fatter. Before this I had only turned slimlines from bushing to bushing. So I guess it was a couple of first with this pen. Overall I am pleased with the pen. It is not perfect but not terrible either. The CA finish went much better then I had anticipated. If you look close there are a few little low spots in the finish but they aren't very noticable. The centerband turned out OK but the fit between the lower and upper barrel isn't perfect. There is a little gap on one side. I guess they weren't squared up well enough. I used bubinga for the blanks and bloodwood for the centerband. Sorry the pics aren't that great. I need to work on my photography skills. Thanks for looking.
Jamie
Jamie
