crabcreekind
This is my first bullet Pen. made from a 30-06 casing my friend gave to me. I glued a long designer tube in the shell. The tube was not in the center of the shell, as you may be able to see, so its not flush on one side, but its a learning process. I used a copper fancy slimline kit for the pen. I polished the shell with scotch-brite then wet mm to 12000. the cocobolo top was turned down to a slimline bushing and i just used the big designer bushing for the side that would sit up against the shell. Then sanded to 600 then 3 coats of medium ca. and 12000 wet mm on the ca, then hut plastic polish. I hope to do more and hopefully get them flush.
