Show Off Your Pens! Let's see your best work! |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
As the title implies, I thought I'd go all out with my first pen. Lot of firsts with mixed results. The glue up was a success (Mesquite burl with Texas Ebony)and I give the solder inlay an A-. The pen turned out nice but for some reason when I trimmed the ends they didn't square up correctly, which is very aggravating to me! I squared with a trimmer from WoodCraft but sanded the extra CA off the end after finishing. Maybe I sanded too much and got into the wood. I didn't think so but it's possible. The CA finish made me want to pull my hair out!! I didn't have any plastic polish or a buffing system so I just made do.
Critiques are welcome and appreciated! (sorry for the cell phone picture) ![]() |
#2 (permalink) |
Nice job and that is a lot of 'firsts'! Did you use the correct size shaft on your trimmer for the tube in that kit? If not that can cause the ends not to be square. Also, the trimmers will not get the ends as square as some other methods.
__________________
Jim West Henrietta, NY |
#5 (permalink) |
Photos:
It very well may be. I tried researching solder inlays for pens, but must not have been searching with the correct terms because I didn't turn up much. I know people are using it for duck calls which is where I got the idea. It may not be ideal, but for learning, it was soft enough to to try easily. I'm open for suggestions to other ways to accomplish this. Adds a nice touch i think.
#6 (permalink) | |
![]() Quote:
Perhaps you were being too aggressive with it and it took at small chunks of material. I imagine it is sharp if it is new but you can also sharpen the cutter. I believe there is an article in the library if you don't know how to sharpen it.
__________________
#7 (permalink) | |
![]() Quote:
__________________
Mal Kids rule the world !!! .... eventually if not already ! |
#8 (permalink) | |
Photos:
![]() Quote:
It was regular rolled solder. The abridged version is to make a groove just narrower than the solder with a parting tool, glue it in and solder the ends together making a seamless piece, then turn down carefully to the diameter of the pen. |
#9 (permalink) | ||
![]() Quote:
Solder the ends together? .... without burning the wood of the pen ?
__________________
#10 (permalink) |
Photos:
Great job for the first. Think about using a disc sander to square or even the lathe. I no longer use the trimmer. I got to much tare out and ripple. Using a small delta disk sander works great. If not happy with that touch it up with sand paper in the head stick and a punch in the tail stock to slide the tube up to the sand paper.
Great first pen. Keep turning. |
Bookmarks |
Tags |
mesquite , newbie , slimline , texas ebony |
Thread Tools | |
Display Modes | |
