Polaris brushed satin with aluminum body.
T tomfree99 Member Joined Jan 7, 2014 Messages 34 Location Centre, Al Apr 3, 2014 #1 Polaris brushed satin with aluminum body. Attachments DSC02110.JPG 132.9 KB · Views: 173 DSC02111.JPG 135.9 KB · Views: 145
SteveJ Member Joined Jul 11, 2012 Messages 3,369 Location Grand Junction, Colorado Apr 3, 2014 #2 Guess it did happen! Interesting pen. It certainly has some appeal.
Falcon1220 Member Joined Jan 9, 2013 Messages 230 Location Vancouver,BC, Canada Apr 3, 2014 #3 Did you use the brass tube inside or did you press the components into your aluminum body?
T tomfree99 Member Joined Jan 7, 2014 Messages 34 Location Centre, Al Apr 3, 2014 #4 Epoxy brass tubes.
T tomfree99 Member Joined Jan 7, 2014 Messages 34 Location Centre, Al Apr 3, 2014 #5 may not use tubes next time. If i am correct a 1/4 inch hole will suffice.
Falcon1220 Member Joined Jan 9, 2013 Messages 230 Location Vancouver,BC, Canada Apr 3, 2014 #6 I try not to use the tube on my aluminum pens. Try to turn the tip and not use the hardware.
T tomfree99 Member Joined Jan 7, 2014 Messages 34 Location Centre, Al Apr 3, 2014 #7 This particular pen requires you to push the click mech down into the tube with a measured extra piece of tube. Might take a little more work to make it fit correctly not using the brass tube.
