A Few from the Weekend
See more from Frihl81
Frihl81
Rocklin, CA
All Wall Street II kits. Gold one is Manzanita. Not sure on the other two. Picked up a box of 100 blanks from WoodCraft and not good with being able to identify different species yet.
Charlie_W
Sterling, VA USA
I lightened your pic slightly so the wood showed better.....hope you don't mind.
I think your pens are looking very nice! Keep up the good work!
mike4066
Akron, Ohio
I like the shape of the second one. I think the Sierra/Wall street style look better when the body follows the line of the front section giving it a bit more width.
When I first started I bought the extra tubes for the WSII and used one kit to go through the pen making process 8-10 times. This kept my costs down while learning those crappy lessons, cracking a blank during drilling, blow outs on the lathe, fit/finish issues. Then disassemble the pen and repeat.
When I ran out of those 5 tubes I turned a few of the bad ones down to the brass and started over. I spent about $12 and went through the process 8-10 times. The pen kit didn't survive unscathed, but still writes and is sitting on my workbench.
Frihl81
Rocklin, CA
Looking good there!
How did you finish these?
Thanks!
All are finished with CA. 4-6 coats thin, sanded with 1500 mm then 4 coats of med CA and wet sanded with MM thru 12000. These are also my sixth, seventh, and eighth pens since deciding to pick up turning pens as a hobby.
