Jjartwood
If you hang enough stuff on a pen sooner or later someone (usually someone you don't want to disappoint ) will ask to cast a favorite item onto one.
A very good friend asked that I hang a NY transportation token he had (his father was a bus driver and had kept it) I wanted to keep the depth of the coin for the full effect but was limited by the thickness from the tube to finished size.
In order to give me more working depth in the PR I decided to try cutting the Zen tube and inserting a 5/16 center insert,this is the first attempt,I think with a little refinement I may be able to fit his full coin,If nothing else I can hang bigger stuff on the tube.
Mark.
Mark.
