Doctors Woodshop Test
See more from mmayo
mmayo
Tehachapi, CA
I have used CA for wood finishes and was only disappointed once when a gorgeous Gabon ebony pen was mistaken for plastic. So for something different I purchased several Doctor's Woodshop products and tried ebony again. This time the grain is apparent and the shine is there, but not as plastic as before. This is not to start pro CA and anti-CA folks going at it, just my attempt to grow a bit.
The above photo does not do justice to the shine and appears matte. These closeup may better show the finish.
Oddly, even after more than 50 CA pens (a weekend for some of you) I felt that the walnut oil technique was less prone to a fatal error. It is hard to see anything except steady progress toward a smoother finish with increasing shine. I like BOTH methods and will use both as appropriate.
76winger
Lebanon Indiana
Ebony is one wood I've never put CA on just because it's hard enough that it doesn't need a protective layer as much, and it's smooth enough not to need a coating that fills in the pores of the wood. My choice for finish has been Shellawax, mostly because that's what I first got for a wood finish and still have plenty left in the big bottle I got. When it's gone I'll experiment with alternatives. Great looking pen with a wonder wood finish!
mmayo
Tehachapi, CA
The "Pens Plus" second step has shellac and microcrystalline wax like Sheelawax and I used five applications followed by several of his wax shine and preservative coats.
BSea
Little Rock, Arkansas
What's the advantage of using the wax shine & preservative coats. Since the pens plus has both shellac & micro-crystalline wax?
I'm not saying it's not a benefit, but I thought the pen's plus was all that was needed after the walnut oil sanding.
BKelley
Tucker, Georgia, 30084
I got introduced to DW about a two months ago and have used it on several pens. I like the look that it gives and I like the ease of application. I personally think that a satin finish compliments wood. With that said, I'll give DW a AA+.
Ben
mmayo
Tehachapi, CA
I sometimes see radial "ridges" and it looks like them in the second photo. Closer views like 3 do not show rings. The last wax preservative treatments have a slick looking finish. Impression you get varies with angle and lighting. It is pretty to me.
