I've casted mini pine cones this week for first time, I have the blanks cut and drilled ready to be glued and turned, I'm wondering what will be the end result, did you stabilize the cones before, I just put it right away, so that's my main concern
I did not stabilize the cones first. I did however keep some thin CA close by
and at random times stop and coat the blank allowing enough time for the CA
to soak in before hitting it with accelerant. I would say to be very careful with the turned blank,the cones make the blank prone to cracks until a good coat of CA is in place.
I cast transparent because I cast in a mold large enough for several molds and by back painting in different colors I don't have 5 of the same blanks at one time
