Hunter1787
Greetings and salutations!
Up for your viewing pleasure today are two Ipad stylus made with the Woodturningz stylus tips. I tried to make one of these several months ago but found that our Ipad requires a conductive stylus which my initial attempt was not. I shelved the idea for awhile because I had a craft show coming up and didn't have much extra time, but then didn't get around to it until yesterday. I used aluminum siding that we had laying around for the slantways thingy (or whatever the proper name is) and it works great.
One thing that is interesting to learn was making a closed end anything. In the end what I did was drill an extra long hole slightly smaller then the standard pen mandrel I use and screwed the end of the mandrel directly into the blank. It worked quite well with very little flexing as long as I didn't push to hard.
The reason for the angle to the aluminum is to try to ensure that most finger positions will have at least one point of contact with the aluminum. Plus I think it looks better then a straight piece across the stylus.
The Styli are about 2 1/2" long and a little less then 1/2" at the widest point.
Any and all comments are extremely welcome.
Thanks for looking,
John
Thanks for looking,
John
