Robert111
This was a commission. I've made bulb fillers before but recently modified the design, including the ink window. Most important, the fill rate is faster--fills completely in five squeezes. Another improvement is the sterling silver furniture. Finally, a Bock cursive italic became available and I couldn't pass it up. Hope you like. Thanks for looking.
Weight 24 g
Length capped 139 mm (5 1/2")
Length uncapped 135 mm (5 3/8")
Length posted 163 mm (6 7/16")
Cap diameter 17.75 mm
Barrel diameter 13.8 mm
Section diameter 12.5 mm
Ink capacity 1.5 ml (twice the capacity of a converter)
Bock polished steel cursive italic
Weight 24 g
