Cobs of Color
See more from Gary Max
Gary Max
Southern Kentucky
Here are some different colored corn cob pens all are on cigar kits
PenWorks
Scottsdale, AZ
Nice cobs Gary, I have yet to turn one in two attempts. What kind of stain did you use? and is that a white one on the end? I bet Margie took the red one.....
Anthony
G
Guest
Guest
Nice job of the color and the pens.
What did you use to tint them?
I've had good luck with magic marker and a "rainbow" effect.
When I try to get them solid teh pattern of the grain dissapears.
Gary Max
Southern Kentucky
Do not tell anyone---I just used plain old food color.
The purple one was to dark--it's one of those two drops of this and 3 drops of that.
The blue on the right was to light.
I sure as heck ain't going to tell anyone--it may be just the color they like.
Anthony thanks for the link on getting the new color of acrylic.
Gary Max
Southern Kentucky
I have only been turning pens for a couple of months. When I found this site I learned a lot about pens and found everyone very helpful. So I will always try to do the same if I can. Some of my post are just how I do something---does not mean it's the right way.
I am not just turning a corncob. I soak them in a polly hardner for a couple hours them let them dry for a couple of days.I start with cobs that are less than 12 % moisture content. This allows the cob to absorb the polly. I also perdrill a 7mm hole in the cob. This also helps the cob to soak up more.
I hope this is of some help.
Gary Max
Southern Kentucky
I buy my cobs from Wallymart---pet food section.
It has been dried. You have to shell it yourself but that only takes a couple minutes. Plus the squirrels like the corn.
