Thank you for the kind words. The final finish is a Myland's Friction Polish. Getting there includes a CA slurry sanding (recommended by Russ Fairfield at a penturner's meeting) to fill any open pores then progressing through the grits. I do this with 220-320 grit garnet paper and medium or thin CA. I took these through 600 grit then hit them with EEE Creme before doing the engraving. Then filled the engraved areas with good old black Rub N Buff to enhance contrast a bit. A note of caution here, make sure the wood pores are filled before applying RnB as it stays where it goes. Another thing I learned - CA is a wonderful solvent for Rubb N Buff. Don't apply more CA after adding RnB to a pen as you'll disolve the pigment and send it everywhere - wasted a beautiful blank with that lesson. I ended up doing the fill, letting the pens sit overnight then hitting them with a good dose of Myland's. They're warm to the touch.
Yes, perhaps I got carried away with the mini billy club... There was something in that blank that made me want to stop right then and there.
All the best, Joe
