Cigar Kit With a 7mm Finial
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
I wanted to be able to make my Rifle Cartridge pens using a Parker refill along with a 7mm Round Top Finial. This is what I came up with using a Wheatherby 300 Magnum and a Deer Antler cap.
It's too bad that you can't buy Cigar kits that use a 7mm finial, maybe some day.
Les
SDB777
Cabot, Arkansas USA
The raduis curves that Weatherby used in his cartridge design look like they make a nice 'curve' for a user to grip the pen with...good thinking! And the upgrade on the ink stick.....big thumbs up!
Scott (everythings good looking here) B
randyrls
Harrisburg, PA 17112
That looks nice!
I don't fully understand the problem you have. I believe you want to use a parker refill and transmission, but use a 7mm finial.
One idea would be to drill the cap partially with 10mm, and then finish with 7mm tube at the top.
rd_ab_penman
That looks nice!
No 7mm tube required, I just modified the cigar cap bushing.
Les
