Originally posted by woodmarc
<br />Beautiful pens. I really like that Snakewood, Gonna have to give it atry.
On soaking the tubes, did you just soak them or did you use vacuum to help the wood absord the tung oil?
Again, great wook
Marc,
Thanks for the compliment. Since it is local to me (small gloat) I bought pure Tung Oil at Grizzly. I cut it a bit (not much on measuring when away from work!) with Mineral Spirits. I dropped the completely finished tubes into the Tung Oil and left them overnight. The container is covered, but no vacuum. The next day, I took them out and wiped them down well, and then let the Tung Oil cure for a month. After that, I just hand polished with a piece of fleece, then buffed 3 coats of TSW on as a protectant.
Remember heat is a HUGE enemy when working with snakewood. I got a small crack or two but filled them with a CA sanding slurry prior to the Tung Oil bath.
Retrospectively, I would recommend wiping out the inside of the tubes after taking the blanks out of the oil.
FWIW,
