Celtic knot made out of deer SKULL
See more from Drstrangefart
Drstrangefart
Woodstock, Ga. U.S.A.
This was a test run for what I hope to be a much nicer one in the kinda immediate future. I need better power tools and more experienced hands to help get the veneers a uniform thickness and sharper tools to stop chatter. Skull veneer hates a chatter. Comments and such are appreciated, as I'm not entirely sure where I stand with this pen.
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
You can certainly use the bushings in conjunction with the calipers to avoid those "oh crap" moments during assembly. Turning close, check it, if all is ok, keep going. It is also wise to check the bushing against the hardware anyway, not all bushings will be accurate out of the box, unless Johnny made them.
Drstrangefart
Right. I've gotten used to being able to get the right bushings out of the box. I ended up using an extra "good" bushing to space the barrels. I did a smart thing and worked them down one at a time, but if I don't space enough when turning separately them there's unintentional grabs that have destroyed good blanks. I should have been more careful in the absence of calipers. I may make a jig to make sure my slims are going well before sanding. I've used wrenches for bullet pens before some bushings showed up.
Brooks803
Aiken, South Carolina
I like it Allan. Be sure to bring it to the meeting (that is if it doesn't sell first!)
One trick I learned with the nib section is to take it all apart and resquare that end. Take it back just enough to where the metal meets the wood. Since you don't have calipers just hold up that good bushing and eyeball it.
Drstrangefart
It should be there with me!
ghostrider
Grand Rapids, Michigan
Outside of the already mentioned I think it looks pretty cool.
I always use calipers, and even then still have a hard time because I haven't developed a consistent formula for finishing. (Thanks to you and some others, I've gotten my finishes looking good, just need to nail down the number of coats, sanding time, etc... that determine the thickness of the finish). I can sand down to just below the bushing, and build up with finish, but where it will be after final polishing is a guess at this point.
Really like the look of that pen. (funny, but I always called it a "Turk's Head" before reading these forums. :biggrin:).
robutacion
Australia - SA Adelaide Hills
Now, segmenting with skull bone, that is getting "cheeky" and not easy. You may get better results in using the bone with a darker wood, for contrast...!:cool:
Yeah, Brooks suggestion is very good, so it is the caliper suggestion from Hunter-27...!:wink:
You can make a jig to help you out, no doubt but, I found one of the easiest ways to solve the problem of a worn bush or a slightly undersized one, even if new, is to rap 1 or 2 layers of masking tape around the bush, flash to the "good" edge.
You just have to remember to not overlap the tape if you only want 1 layer of tape. You can make it safer and add 2 layer of tape, 1 to guide you with the barrel size (rough turn) and remove 1 layer to guide you for the hand sanding.
You can use different colours for the layers and you can always replace the tape if it gets damaged before you're ready...!:biggrin:
It doesn't take more than a few seconds to rap some tape to the bush(s)...!:)
Good luck...!
sbell111
Franklin, TN
Honestly, I'm not loving the caliper suggestion. It is simply easier for me to turn using bushings. I do incorporate calipers as a way of occasionally checking bushing wear, but never as a replacement for bushings (except for those relatively rare scenarios where there is no bushing for the job, of course).
Drstrangefart
I don't REALLY wanna have to learn, but at least being able to double-check would be an improvement. Idiot proofing me from myself seems to be a full time job these days.
