propencity
A mishap while turning the body. Not wanting to waste it the barrel, I turned a lower threaded finial to allow access to the converter for refilling. Nib is #6 Meisternib (Broad). Also my first time using 10x1 tap/die for the section/body connection; I often crack the tenon using the 9mm tap/die.
