Bullet Pen - 308 Caliber Dressed in Antler
See more from JD Combs Sr
JD Combs Sr
Owingsville, KY
Yesterday I made another kit-less bullet pen. This one is from a 308 cartridge with a 155.5 grain bullet.
It uses a cigar type 8mm transmission, the same clip/finial as the 8mm Mauser, and it has a Parker gel writer type refill. Yesterday's 8mm Mauser used a 7mm slimline transmission with a standard cross ball point refill.
The upper barrel is turned from deer antler. The amber colored spots are a few of the antler "wrinkles" that were inside the curved part of the horn. They are actually surface depressions instead of spots.
Here is a couple of standard views.
The rest of these shots I was just trying to be different from my usual standard shots.
JD Combs Sr
Owingsville, KY
Not seeing the photo's....and I really want too!
Scott (please retry) B
Should be OK now. Original photos were copy/pasted from Sawmillcreek.org and I didn't realize the small images would link to SMC. You were probably trying to see them while I was editing the post uploading the original photos.
SDB777
Cabot, Arkansas USA
Thanks! I see them now!
Always like the 'real cartridge' look. And the antler turned out very good also!
Scott (great fit-n-finish) B
bitshird
Adamsville, TN, USA.
Nice work, but I think the Satin Pearl clip kind of clashes with the bright shiny brass casing, however this is just my unpolished opinion.
JD Combs Sr
Owingsville, KY
It's actually chrome but I agree. It was the only one I had but I have since order some gold ones. They may coordinate a little better with the shinny brass.
Thanks for the critique, it confirmed my impression as well.
